http
    Configures the HTTP server settings used
      to authenticate HTTP connection to a EX3500 switchManagement
        access to an EX3500 switch can be enabled/disabled as required
        using separate interfaces and protocols (HTTP, SSH). Disabling un-used and insecure
        interfaces and unused management services can dramatically reduce an attack footprint and
        free resources within an EX3500 management policy.
        - Service Platforms — NX 95XX, NX 96XX, NX 7510
    Syntax
      http [port <1-65535>|secure-port <1-65535>|secure-server|server]
    Parameters
              | http |
              Configures following HTTP settings: port, secure-port, secure-server, and
                server |
              | port <1-65535> |
              Configures the HTTP port number. This is the port used to connect to the HTTP
                  server.
                  - <1-65535> – Specify a value
                    from 1 - 65535. The default port is 80.
              | secure-port <1-65535> |
              Enables secure HTTP connection over a designated secure port. Ensure that the
                HTTP secure server is enabled before specifying the secure-server port.
                  - <1-65535> – Specify the
                    secure HTTP server port from 1 - 65535. The default port is 443.
              | secure-server |
              Enables HTTP secure server. This option is disabled by default. |
              | server |
              Enables HTTP server. This option is enabled by default. Consequently, HTTP
                management access is allowed by default. |
      nx9500-6C8809(config-ex3500-management-policy-test)#http secure-server
      nx9500-6C8809(config-ex3500-management-policy-test)#show context
ex3500-management-policy test
 http secure-server
 enable password level 3 7 12345678901020304050607080929291
 snmp-server notify-filter 1 remote 127.0.0.1
